Pulling tractor with a deuce engine
welldigger
17
Benton LA
Why would that suggest a different injector? The head castings are supposed to be the same.
Casting yes. Doesn't mean the machining is the same. It could be. I don't know either way.
Though, typically I see roosamaster pumps with cva injectors. Obviously this combination doesn't apply to every engine.
JasonS
202
Eastern SD
If you do a google image search for: white 2-135, 2-155 farm tractor diesel injectors WORK GREAT! or
white 2-135, 2-155 farm tractor diesel injection pump WORKS GREAT! you will find pictures from apparently expired ebay auctions showing what look exactly like mulfituel injectors and the corresponding roosamater pump; both from the same seller.​
w3azel
Waipahu/HI
Awww, yep I'm an idiot. I was wanting the 2-155 and clicked on 2-150 instead. Well forget what I say, instead make sure you select the correct one. BTW if you want to know a 2-150 Injector it's about half the radius of the Hercules injector. I ordered it for $45, didn't show up for two month. So when it arrived I saw how wrong it was but the paperwork was right I just threw it into a pile of parts.
