Pulse Tech Solargizer Questions
WhoMe08721
123
Bayville/NJ
Hey guys,
Was looking into buying a Pulse Tech Solargizer for my M35A2 & M998. But had a few questions
1) Are they worth the money?
2) Are the electronics waterproof for fording deep water?
3) What the difference in military vs civilian version?
4) What model is the best to get?
Finally I was looking at the IS-24-L any good???
kendelrio
9,438
Alexandria, La
I bought one from @Csm Davis for my 5 ton and I don't regret it. I mounted the "box" with velcro behind my passenger seat in the cab.
Rather than hard mount my panel to the roof, I left it loose so I can place it for maximum sun exposure
And to facilitate storing (I have a box I put it in when not in use to keep it from being in the way/damaged) I installed non-reversable connectors (so I can't mess up polarity).Resized_20220529_110408(1).jpeg
I love it because not only does it condition the battery, but it charges the battery pretty quickly and I can run my stereo all day and not worry about it.
As far as waterproofing, how deep are you going? If you mount the box high enough in the cab, you have no worries.
MarkM
1,146
2,096
WOBURN. MA.
Great product but get the military one. As I recall it pulses at around 36 volts and keeps sulfates from forming on the cell plates of the battery. Meant to keep the battery in a good state for months. My M998 sits outside and hardly ever use it in the winter to keep Massachusetts rock salt off her. Always fires right up and fording is not a problem. Two thumbs up from my end. I mounted mine in the normal place for M998 which is on the flat part of the hood just above the pass directional light. Just my two cents.
Mark
juanprado
3,167
Metairie/La (N'awlins)
The civy version is usually 12v and the military is 24v. The Is24L is the common sized one seen on most mv's. The one Kendelrio pictured is a different model with a larger panel. I believe the IS24L is water proof or resisant as the small box looks totally sealed and just has 2 wires coming out. If not a dab of silicone should take care of that.
Csm Davis
405
Hattiesburg, Mississippi
Hey guys,
1 definitely worth it
2 the panels are very weather proof, not sure about the little boxes as they are meant to be mounted in or near the battery box, but they should be.
3 mainly color of the panels I believe that they make 12 and 24 volt versions of both
4 they are all good but the small panels are not going to keep the batteries topped off, the one I like the best is very expensive but does lots of extra things besides just keeping the batteries alive.
Best testimonial I have is I found a set of batteries in a 5 ton cab that had been sitting for 2-3 years after we cut the cab off the truck, had only the small panels on it but we pulled the batteries an they took a full charge!
