- 2,763
- 945
- 113
- Oakwood, Ga
Subscribed
TMike your experiance and feedback is greatly appreciated.
16 (27SI) -- per the Delco Remy specification guide for the SI series Alternators....how many poles are in the stock alternator?
It is the "R" terminal on your Alternator - that is the "phase Tap". It comes directly off the diode pack (rectifier). A "phase tap" is connected to any one of the three winding terminals on the rectifier- one of the three "phases". That wire then goes to the Tach Buffer Module next to the STE/ICE port. It goes through the Tach Buffer Module before heading out to the STE/ICE diagnostic port. The Tach Buffer module conditions the phase tap signal --- but in my case the wave form directly out of the Alternator was by far the cleanest that I could find. I probed every port number on the plug. Maybe I have a bad tach buffer module.??Where is this?
Alternator "Phase Tap" (brown wire off of Tach Buffer module under dash)
I hate to admit it; I do like to do basic wiring but I can't read an electrical schematic. I've only done the doghead starter relay mod because someone was nice enough to post pics of the thing. That worked out well, btw. But I'd appreciate it if someone would post a pic of the brown wire off of the Tach Buffer module under dash. I can do this with the info given, but I'd also like to avoid running another wire through the firewall. I really would greatly appreciate it if you or anyone else so inclined would post a pic of this. That'd make it sticky-worthy imho. Thanks.I hooked up (3) wires -- 12v, Ground, and the Alternator "Phase Tap" (I hooked up (3) wires -- 12v, Ground, and the Alternator "Phase Tap" (brown wire off of Tach Buffer module under dash)
