question about PTO shift shaft boots
darksheep85
Newberry, SC
I've got my transmission out to do a clutch job and re-gasketing the Trans and PTO. Here's the question: the PTO shift shaft has threaded ends and the linkage screws into one end and the other end just has a bolt and washer. With new boots going on, is the shaft supposed to protrude out both boots or is there a way to attach the ends of the boots to the ends of the shaft so it's 100% sealed? What am I missing? It's all apart right now because I'm waiting on a new PTO shift fork. Do the boots even stretch enough to accommodate full extension when shifting? That is, if they are somehow attached to the ends of the shaft.
rustystud
3,392
Woodinville, Washington
Your talking about the PTO shift shaft correct ? The rubber bootie should totally seal the shaft. There should be a washer and nut that holds the end of the boot against the end of the shift shaft and the linkage.
