Question on a "sprag" transfer case
appnut1
Winter Springs Florida
I am in the proces of bobbing my duece and I am waiting on a longer drive shaft to be made.When I went to move the truck on the front axle I put it 1st gear and nothing, put it in reverse and nothing, put the transfer case in low and nothing, in all three scenerios the rear axle output on the transfer case was spinning but nothing out the front :cry: .
Does anyone have a clue on where to start looking and how big of a deal is the likely repair, I do not have the funds right now to do an air shift.
WillWagner
2,440
Monrovia, Ca.
Re: Question on a "sprag" trabsfer case
It is a very simple job. You still have the bed off ? Just put an airshift and be done with it. 4 to 6 hours of labor and the t-case isn't that much...$350 tops. Trust me, you'll be much happier with your truck.
appnut1
RE: Re: Question on a "sprag" trabsfer case
Anyone want to trade an airshift case and all needed hardware and valves for a complete hub to hub rear axle with tourque rods and bogey set up?
DDoyle
80
West Tennessee
I'd say with a large degree of confidence that you need to adjust your transfer case linkage. There is a sticky posted in this forum that tells you how to do this.
HTH,
David Doyle
appnut1
Dave, I was under the impression that the sprag was over ridden when the transfer case is placed in low range
m16ty
210
Dickson,TN
Re: RE: Re: Question on a "sprag" trabsfer case
No, The front axle only kicks in when the back tires spin or in your case as soon as the back output of the t-case spins it should kick in. High or low dosen't matter.
1,331
decatur alabama
RE: Re: RE: Re: Question on a "sprag" trabsfer cas
Appnut1 i got a real good air shift 2.5 case that i think still has never been installed since it was rebuilt by uncle Sam. Let me know if you need it, if you decide to swap yours out
