ZZ4x4
- 1
- 8
- Sachse, TX
Hey all,
I've installed a donor 6.2 into my HMMWV and I'm having one heck of a hard time getting it to start. The wait to start light comes on for the right amount of time. It will crank for several minutes ( 20 secs at a time) with not so much of a kick. Then it may slowly fire a cyl or two , catch, and run for 2 seconds max and then die. Then it's another couple minutes of cranking with nothing.
Just FYI the entire fuel and glow plug systems are new.
I've done the following things:
It sure seems like she is fuel starved but the IP is full of fuel with extra fuel rising out of the IP return hose. Does the mech fuel pressure affect performance? I was under the impression the lift pump in the IP doesn't care about input pressure as long as there is fuel.
I installed a clear fuel return line on the top of the injector pump. I get a little bit of fuel which slowly rises into the line and trickles out. Not a huge flow. I do still get some bubbles in this line. The bubbles and very low flow concerns me. Does anyone know if the small amount of flow is normal or should I be seeing a large flow? I read one HMMWV manual instructing the driver of a run-away engine to pinch that hose to shut the engine. How would that stop the engine when the fuel is still being pumped into the IP from the other end. It would just build a little more fuel pressure in the IP. Nevertheless I'm leaning towards a mech fuel pump problem. Any confirmation or ideas?
Should I play with the timing?
Thanks,
Jeff
- New Fuel tank and lines
- Fresh Diesel
- New rebuilt injector pump from reputable company
- New engine wiring harness
- New digital Smart Start controller and temp sensor
- New Fuel filter
- Compression check in all cylinders. All good
- Glow plug resistance checked. All are 1.6 ohm
- Glow plugs are getting 24V when wait light is on.
- Injector pump shutoff solenoid is getting 24 V. Can hear click of injector pump solenoid.
- Fuel weeps from all injector lines when cracked
- Fuel weeps from filter bleed screw when cracked
- Added extra ground to block.
Thanks,
Jeff
