Question on the M939A2 rear axles plastic bushing sleeve?
MuleMac01
Military vehicle collector
158
Las Vegas Nevada
My M923A2 right axle was leaking ctis air out of it innter seal so I took it apart,... I'm replacing all the seals inside the hub just to be sure and my bearings look great but my question in the plastic axle bushing sleeve how do you know it needs replacing? does it wiggle inside the axle hub? what are the signs of a bad one. and what purpose does it serve? also the ctis seal inside the hub are they both the same or deferent? some people say I can use 2 of the same some people say you cant is that true?
MuleMac01
158
Las Vegas Nevada
So no answer to this question? It's been a week thought someone would know. The Tm says to replace if you see ware / or damage but what are the signs? well anyhow I'm putting the axle back together in the next few days.
silverstate55
Unemployable
873
UT
Sorry William, haven't been into my rear hubs so I couldn't tell you for sure.
