- 916
- 187
- 43
- Las Vegas Nevada
My M923A2 right axle was leaking ctis air out of it innter seal so I took it apart,... I'm replacing all the seals inside the hub just to be sure and my bearings look great but my question in the plastic axle bushing sleeve how do you know it needs replacing? does it wiggle inside the axle hub? what are the signs of a bad one. and what purpose does it serve? also the ctis seal inside the hub are they both the same or deferent? some people say I can use 2 of the same some people say you cant is that true?
