Question re: date / mileage markings
Ddk2001
Folsom/CA
I'm looking at a few HMMWV's this week - likely going to make a decision this weekend. One I'm looking at has what appears to be a date (month/year) and mileage painted in a few places (front cross-member, trans pan). Current owner says motor and trans were replaced (it's a '92 with a 6.5NA). Anyone have any insight on the markings?
Thx
-D
emmado22
138
Mid Hudson Valley NY
All that SOUM means is that the unit checked/repaired the washers in the hubs. Those markings don't mean ANYTHING for any other component replacement. Google SOUM 08-017
Retiredwarhorses
3,893
Brentwood, Calif
Trucks got new motors during reset, many were done in Maine at the reset facility. Just depends on what program they went through, IROAN "inspect repair on as needed basis", or full body off...I have trucks done from 02-09.
many have rebuilt 6.2's. Look for an MMA decal....may or may not be one though.
All MWO's were applied during any of these programs...at least safety MWO's anyway...brakes, steering column, spindle nuts...etc.
some trucks are true gems and still have all the docs and decals, others were defaced and removed by soldiers.
Retiredwarhorses
3,893
Brentwood, Calif
bject: SOUM 00-017, TECHNICAL, GEARED HUB LOCKWASHER, HMMWV
R121509ZJUN00
> TEXT
> :UNCLAS
> SUBJECT: SAFETY OF USE MESSAGE (SOUM), TACOM CONTROL NO. SOUM-00-017
> UPDATE FOR TECHNICAL, GEARED HUB LOCKWASHER, NSN 5310-01-213-4185,
> FOR ALL M998 SERIES HIGH MOBILITY MULTIPURPOSE WHEELED VEHICLES
> (HMMWV).
> D XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX D
> A X "WARNING" X A
> N X DEATH OR SERIOUS INJURY TO SOLDIERS, OR DAMAGE X N
> G X TO ARMY EQUIPMENT WILL OCCUR IF THE INSTRUCTIONS X G
> E X IN THIS MESSAGE ARE NOT FOLLOWED. X E
> R XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX R
> REFERENCE:
> A. MSG, 181759Z, MAY 00, TACOM-WRN CONTROL NO. SOUM-00-014, SUBJECT:
> SAB.
> 1. DISTRIBUTION:
> A. THIS IS A TECHNICAL SAFETY OF USE MESSAGE. MACOM COMMANDERS
> WILL RETRANSMIT THIS MESSAGE TO ALL SUBORDINATE COMMANDS/ACTIVITIES
> WITHIN 24 HOURS OF RECEIPT OF THIS MESSAGE AND ACKNOWLEDGE RECEIPT OF
> THIS MESSAGE WITHIN FIVE WORKING DAYS TO: CDRTACOM, WARREN MI//
> AMSTA-LC-CIPWM// DSN 786-6096, COMMERCIAL (810) 574-6096 OR DDN
> ADDRESS: SAFETYOFUSE@TACOM.ARMY.MIL. MACOMS NOT RESPONDING WILL BE
> CONTACTED BY TACOM.
> B. MACOM COMMANDERS WILL ALSO TRACK AND REPORT COMPLIANCE OF THIS
> MESSAGE FOR ALL SUBORDINATE COMMANDS/ACTIVITIES TO EITHER MR. AL
> YASONI, HMMWV LOGISTICS MANAGER AT TACOM, DSN 786-8398 OR MS. JODY
> MCINERNEY, HMMWV EQUIPMENT SPECIALIST AT TACOM, DSN 786-6277 WITHIN
> 30 DAYS OF RECEIPT OF THIS MESSAGE.
> XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
> 2. PROBLEM:
> A. THIS MESSAGE IS AN UPDATE TO SOUM 00-014, AND SHOULD PROVIDE
> SOME NECESSARY CLARIFICATIONS. FIRST, THIS MESSAGE AND REFERENCED
> MESSAGE (SOUM 00-014), APPLY TO ALL HMMWV MODELS. AS STATED IN
> REFERENCED MESSAGE, PARAGRAPH 3C, IF YOUR VEHICLES WERE RECEIVED
> THROUGH NEW EQUIPMENT FIELDING AND YOU HAVEN'T PERFORMED GEARED HUB
> MAINTENANCE AND/OR YOUR SEMI-ANNUAL GEARED HUB PMCS, YOUR VEHICLES
> ARE EXEMPT FROM THESE MESSAGES.
> B. WE HAD A REPORT FROM THE FIELD THAT A WHEEL FELL OFF A HMMWV.
> THE INVESTIGATION RESULTS CONFIRMED THE CAUSE WAS NON-COMPLIANT
> LOCKWASHERS IN THE SUPPLY SYSTEM. THE NON-COMPLIANT LOCKWASHERS
> MEASURE .120 INCHES THICK. THERE IS A POTENTIAL OF APPROXIMATELY
> 44,000 PIECES OF NON-COMPLIANT LOCKWASHERS. THE PROBABILITY THAT
> THESE LOCKWASHERS ARE STILL IN USE IS REMOTE, HOWEVER, THE RISK OF
> SERIOUS INJURY, DEATH TO PERSONNEL OR DAMAGE TO EQUIPMENT IS HIGH.
> 3. USER ACTIONS:
> A. REFER TO SOUM 00-014; PARAGRAPH 3B AND 3C REMAIN THE SAME.
> THE INSTRUCTIONS BELOW ARE SUPPLEMENTAL TO THOSE PROVIDED IN
> PARAGRAPH 3A AND 3D OF SOUM 00-014, DATED 18 MAY 00.
> B. USER SUPPLY CLERKS AT ALL LEVELS ARE REMINDED TO INSPECT
> LOCKWASHER, NSN 5310-01-213-4185, STOCK (I.E., BENCHSTOCK, SHOP
> STOCK, ASL AND ANY SERVICE STOCK) AND DISPOSE OF ANY SUSPECT OR
> NON-COMPLIANT STOCK PER AR 710-2.
> C. VEHICLES ARE EXEMPT FROM INSPECTION IF USERS CAN POSITIVELY
> DETERMINE THAT THE NON-COMPLIANT LOCKWASHERS, NSN 5310-01-213-4185
> ARE NOT INSTALLED ON THEIR VEHICLE THROUGH THE FILE COPY OF THE LAST
> RECORDED MAINTENANCE SERVICE RECORDS, AS WELL AS ANY NEW EQUIPMENT
> FIELDED VEHICLES FROM PRODUCTION (THAT HASN'T UNDERGONE GEARED HUB
> SERVICE). IF THERE IS ANY DOUBT OF THE TYPE OF LOCKWASHER INSTALLED
> OR IT'S SERVICEABILITY, THE VEHICLE MUST BE INSPECTED. ALL HMMWV
> FLEET VEHICLES THAT DO NOT MEET ONE OF THE TWO LISTED EXEMPTION
> CRITERIA MUST BE INSPECTED. THE INSPECTION AND MEASUREMENT MUST BE
> CONDUCTED WITHIN 45 DAYS AFTER RECEIPT OF THIS MESSAGE. THIS
> INSPECTION AND MEASUREMENT CAN BE ACCOMPLISHED AT ORGANIZATIONAL
> LEVEL MAINTENANCE. ANY HMMWV FLEET VEHICLE THAT HAS NOT HAD THE
> DIRECTED INSPECTION COMPLETED AFTER THE 45 DAY PERIOD WILL BE "NON
> MISSION CAPABLE" UNTIL THE INSPECTION IS COMPLETED AND CORRECTIVE
> ACTIONS TAKEN AS NECESSARY.
> 1. WE HAVE VERIFIED THAT THE INSPECTION/MEASUREMENT CAN BE
> DONE BY REMOVING THE WHEEL ASSY (TM9-2320-280-20-2, PARAGRAPH 8-3),
> DRAINING THE GEARED HUB (TM9-2320-280-20-2, PARAGRAPH 6-14, STEP 1
> AND BY REMOVING THE STEERING ARM COVER (TM9-2320-280-20-2, PARAGRAPH
> 6-14, STEP 2). THERE IS NO NEED TO REMOVE THE LOCKWASHER. YOU CAN
> VISUALLY CHECK FOR BREAKS/CRACKS AT THE BEND. IF NO CRACKS/BREAKS ARE
> VISIBLE, MEASURE THE THICKNESS OF THE TAB. THE FOLLOWING SUGGESTED
> PROCEDURES HAVE BEEN RECEIVED FROM THE FIELD AND ARE PROVIDED AS
> ALTERNATIVE METHODS WHICH CAN BE USED TO ACCOMPLISH THIS TASK AT THE
> ORGANIZATIONAL LEVEL:
> A. MECHANICS ARE TO REMOVE THE STEERING ARM COVER AS PER
> THE TECHNICAL MANUAL, CLEAN THE LOCKWASHER TAB SURFACE AND INSURE THE
> LOCKWASHER BENT TABS ARE FLUSH AGAINST THE SURFACE OF THE LOCKNUT
> SLOT.
> B. USING A 7/64 INCH ALLEN WRENCH, COMPARE THE ALLEN
> WRENCH TO ONE OF THE LOCKWASHER TABS BY ALIGNING THE 7/64 INCH ALLEN
> WRENCH WITH THE END OF THE LOCKWASHER TAB. IF THE LOCKWASHER TAB
> THICKNESS IS EQUAL TO OR LARGER THAN THE 7/64 INCH ALLEN WRENCH
> THICKNESS, REPLACE THE LOCKWASHER. IF IT IS LESS THAN THE 7/64 ALLEN
> WRENCH THICKNESS, YOUR LOCKWASHER IS CONSIDERED SERVICEABLE.
> C. ANOTHER METHOD TO CHECK THE LOCKWASHER THICKNESS,
> OTHER THAN USING THE 7/64 INCH ALLEN WRENCH, IS TO COMPARE A
> KNOWN GOOD LOCKWASHER, NSN 5310-01-213-4185 TO ONE OF THE LOCKWASHER
> TABS INSTALLED IN THE GEARED HUB. THIS CAN BE ACCOMPLISHED BY
> SIMPLY SLIDING THE KNOWN GOOD LOCKWASHER AGAINST THE LOCKWASHER TAB
> INSTALLED IN THE GEARED HUB. IF THE LOCKWASHER TAB THICKNESS IS
> LARGER THAN THE KNOWN GOOD LOCKWASHER THICKNESS, REPLACE THE
> LOCKWASHER. IF THE THICKNESS IS EQUAL TO OR LESS THAN THE KNOWN GOOD
> LOCKWASHER THICKNESS, YOUR LOCKWASHER IS CONSIDERED SERVICEABLE.
> 2. THE ONLY ALTERNATIVE TO THE PROCEDURES ABOVE OR THE
> PROCEDURES STATED IN PREVIOUS SOUM 00-014 IS REPLACEMENT OF THE
> LOCKWASHER.
> C. UNIT COMMANDERS, CONTACT YOUR LOCAL TACOM LOGISTICS
> ASSISTANCE REPRESENTATIVE(LAR) OR YOUR STATE SURFACE MAINTENANCE
> MANAGER UPON RECEIPT OF THIS MESSAGE FOR ASSISTANCE. FOR ASSISTANCE
> IN LOCATING YOUR TACOM LAR, SEE PARAGRAPH 6C.
> 4. TACOM/PM ACTIONS: THE INFORMATION PROVIDED IN THIS MESSAGE WILL
> BE PUBLISHED IN AN EQUIPMENT IMPROVEMENT RECOMMENDATION (EIR) DIGEST
> ARTICLE (TB 43-0001-62) NLT 4TH QTR FY00.
> 5. SUPPLY STATUS: THE LOCKWASHER, NSN 5310-01-213-4185, IS DEFENSE
> LOGISTICS AGENCY MANAGED AT S9I, DSCP, PHILADELPHIA. THERE ARE
> CURRENTLY 21,538 LOCKWASHERS IN STOCK WHICH S9I IS CONTROLLING
> FOR RELEASE OF HIGH PRIORITY REQUESTS. THERE ARE ALSO 239,000
> CURRENTLY ON ORDER AND EXPECTED AWARD OF AN ADDITIONAL 200,000 WITHIN A
> WEEK. PROJECTED DELIVERY RUNS FROM 50,000 TO 100,000 PER MONTH
> THRU OCTOBER 2000.
> 6. POCS:
> A. MS. JODY MCINERNEY, HMMWV SUSTAINMENT TEAM, DSN 786-6277,
> COMMERCIAL (810) 574-6277, E-MAIL: MCINERNJ@TACOM.ARMY.MIL
> B. MR. AL YASONI, HMMWV LOGISTICS MANAGER, DSN 786-8398,
> COMMERCIAL (810) 574-8398, EMAIL: YASONIA@TACOM.ARMY.MIL.
> C. TO FIND YOUR TACOM LAR, LOG ONTO THE ARMY ELECTRONIC
> PRODUCT SUPPORT WEB SITE AT HTTP://AEPS.RIA.ARMY.MIL. ONCE LOGGED
> INTO THE AEPS SITE, SELECT THE LAR LOCATOR SERVICE, THEN SELECT THE
> APPROPRIATE REGION, I.E.: CONUS, USAREUR, FAR-EAST, KUWAIT. SELECT
> THE LOCATION NEAREST YOU AND CLICK ON A NAME. THIS WILL GIVE YOU A
> LAR'S NAME, DSN AND COMMERCIAL PHONE NUMBER, EMAIL ADDRESS, AND
> PHOTO. IF YOU DON'T HAVE ACCESS TO AEPS, YOU CAN ALSO OBTAIN THIS
> INFORMATION BY CONTACTING THE TACOM SENIOR COMMAND REPRESENTATIVE
> (SCR) FOR YOUR AREA. CONUS (INCLUDES NATIONAL GUARD, CONUS ARMY
> RESERVE UNITS, SOUTHCOM, AND KUWAIT) DSN 367-6204/6293, COMMERCIAL
> 404-464-6204/6293; USAREUR (GREAT BRITAIN, GERMANY, BELGIUM,
> LUXEMBURG, ITALY, BOSNIA, KOSOVO, AND MACEDONIA) DSN 375-6128/7436,
> COMMERCIAL 01149 621-487-3461/6218, FAR EAST (INCLUDES ALASKA,
> HAWAII, KOREA, OKINAWA, KWAJALIEN, AND JAPAN) DSN 315-722-6036,
> COMMERCIAL 011 82 32 520-6036/6881.
> __________________________________________________________________________
> __
Retiredwarhorses
3,893
Brentwood, Calif
This can be somewhat misleading, the newer spindle nut has 8 spots for foldable tabs, the old has 4, the new gets 2 tabs folded over the old only gets one....you want the new style.
