Questions about a part from my air compressor
Lonesome715
24
Columbus, GA
Pictured below is a part that came off the top of my compressor. I have had it apart fro so long I do not remember how it goes back together. The compressor itself has been reassembled for quite a while. I held off on this part because it got mixed up with something else. I am not even sure what it does. Is it a check valve? I need to know how it goes back together so I can wrap this part up. I have looked at diagrams in the TM section but none of the diagrams I have found shows this specific part or how it goes back together. Does any one here know?
Lonesome715
24
Columbus, GA
That link if gor the regulator that mounts on the fire wall. The part I am dealing with installs right on top of the head on the compressor.
Lonesome715
24
Columbus, GA
I also did not realize it needed a gasket. My rebiuld kit for the compressor did not include one. I am glad you brought that up. I will see if I an make one from some gasket material i have.
gringeltaube
Staff Member
2,428
Montevideo/Uruguay
Use thin gasket paper, or some gasket maker like Loctite 518.
Not really critical here.
Yes for some light grease. I will assemble this with silicon grease, which I prefer anytime over mineral grease, in all the air system...
And YES, the cups go in first, with the lip facing inward.
G.
