TSmallwood
- 0
- 0
- Commerce, GA
I have been loking for a Deuce not to far from home (in GA) to buy.
I have found a M35A2C numbers MK0483 0560-11099 for sale here in town.
The guy is wanting around 4k for the deuce my QUESTION to you guys is is it worth it.
Here is the things that I looked at and found out about the Deuce.
11,000 miles didnt get the hours.
rust on the hard top almost all the way through above both doors.
there is about a 1/4 inch gap between the door and cab on the drivers side when shut
about 3 tires dry rot
no winch but has the PTO for it
still has seat rails with the wood in the bed
WAS told by the owner that if the batteries are left connected over a few days they will drain and deuce will have to be jumped off
there is a little rust here and there not to bad
the under side is in really great shape
the drivers side hub is leaking alittle wet on the wheel
cab is in good shape all gages look to be in geat shape
seats are good no tears
did not get to drive or crank up
under the hood no wet spots on motor
hood has a dent but not bad
body could use a paint job
was told that it is a 1983 model
What i am asking you guys is this deuce worth around 4,000 dollars and what woud it take to turn this baby in to a reliable work truck for farm and off road use
any info or help would be nice
