top_prop
- 8
- 18
- Suffolk, VA
Thanks for the reply needed that confirmation![]()
You probably already know this.... but I'm going to post it anyways... Remember you only need to do the doghead on a truck with the standard 24v starter.... if yours has been converted to 12v, you don't need a new relay... you can just bypass it as it is how the stock 12v ignition switch controls the 24v starter/solenoid...
The way to know for sure is to put a volt meter on the big red lead running to the starter and see what voltage it has to ground.
Tom
