Questions about pulling a M919 with a tow bar
cundupa
Holland, MI
Has anyone pulled a M919 or 920 size truck with a tow bar? I know the rear drive axles need to come out, is there something made to take their place? Is there a light connector on the front for tail/marker lights?
Do they follow good at highway speed?
Thanks!
BKubu
1,124
Gaithersburg, MD
What are you going to tow it with? My reco is to use a truck that is at least as heavy as the M919...and try to hook up the brakes.
cundupa
Holland, MI
If it works I'll pull it with another site mix truck that weighs about 31000lbs. That truck has a 435 hp 60 series Detroit. It has air lines to the back, tractor protection valve, trailer brake valve in the cab etc. so it WILL have brakes and lights.
I need both trucks moved from Michigan to Cherry Point NC next month, thought I could save a little by towing one.
Oshkosh equipment has new bars for $600, probably what shipping would cost from Washington!
cundupa
Holland, MI
Tow bar purchased, test pull completed!
I noticed the red supply air line tees into a line just before the air tank, but there is a check valve between the tee and the tank. If the line to the back truck broke or the truck broke free the check valve would hold the air psi and not allow the brake to come on. Shouldn't the supply be between the check valve and the tank? I looked it up in a TM and it shows Tee, check, tank.
Any thoughts?
