Questions regarding 3l80 Transmissons and down shifting
AOR
24
Burtonsville, MD.
I am a new to owning a HMMWV. I have a 1986 with the 3L80 3 speed setup. Should it downshift on its own when pressing the accelerator down to the floor and at what speeds would it downshift?
Also there is a cable that connects onto the passenger side that has a minor leak does anyone know exactly what it is for? I have been told very different things from people who deal with these every day.
dhaumann69166
77
Hyannis, Nebraska
The turbo 400 will downshift but you have to be lugging around at pretty low RPM and put it all the way to the floor. I usually shift manually when driving mine just to keep better control of the RPM and not make it lug around so low. The only time I have had mine kick down a gear is starting into a soft sand hill climb and usually I try to have it in the desired gear before starting into the obstacle. 6.2 is a low RPM motor so don’t expect it to grab a gear and rap up hard like modern vehicles. Also when you put it flat to the floor your clutch fan should shut off for 30 seconds.
