Quick 24 to 60 Alt Question
Kenny714
-1
Forked River,NJ
I got the conversion kit installed except for the wire that goes to the master/ignition switch. I started unwrapping the harness to figure out which wire is the correct one to remove from the switch and plug into the 3way and jumper wire, but am running into problems. The original wires are brittle and I am worried about cracking off all the rubber insulation. Does any one know which plug on the back of the switch is the right one? I've got the schematic (TM 9-2320-361-20), but can't figure out which plug is the "D". I gues the easiest way to answer would be...looking at the switch installed would it be the 2:00, 4:00, 8:00 or 10:00?
Thanks in advance,
KENNY
Kenny714
-1
Forked River,NJ
Works like a charm! :-DFires up like it never did before! I'm getting 27.8 volts at the batteries with the Fluke when the motors running.
Thanks!!!!!
