Quick Blackout circuit question.
980
24
Dover, New Hampshire
Hey fellas, quick question about the blackout light system.
I was demonstrating it for someone the other night and realized I could not get my front markers to turn on. My headlight and tail lights come on fine but could not get my B/O front markers to illuminate. The next day I opened the housings to take a look and the bulbs looked fine, nevertheless I swapped them out with no success. I checked the wires coming into the housings with my test light but got nothing from either side.
Now I don't intend on using my blackout lights in any practical capacity in the near future but I do like to keep everything in functioning condition. Before I rip my dash apart, could I have a faulty switch? I didn't think so since my rear markers were working fine but now I am assuming they are on a different circuit.
I was thinking of upgrading to the new style switch anyway.
-GM
NDT
6,303
Camp Wood/LC, TX
The BO markers on the front and rear are (edit: NOT) the same circuit coming out of the 3 lever switch. 20 is front and 24 is rear
Gunzy
66
Roy, Utah
I don't recommend the new electronic switch unless you are converting ALL of your lighting to LED as the incondesent lighting draws a lot more current than the LEDs do and people have had the electronic switches burn/catch fire when operating incondesent lighting. If you have another switch available plug it in and retest your lighting. Had the oppisite problem on an M998, blakouts but nothing else. A replacement switch got all the lights working.
emmado22
147
Mid Hudson Valley NY
The pushbutton LED switches are nice until they short out and start an electrical fire, regardless of LED or incandescent bulbs.
980
24
This turned out to be a bad ground on both left and right sides, I had forgotten to completely tighten the light enclosure mounting bolts when I reinstalled them after paint. They became excessively loose and I started losing lights until I saw what I had done :roll: Thanks everyone for the info!
-GM
dmetalmiki
2,027
London England
Glad you solved the problem I like to have everything working that is original. And spent many a day cleaning connections and earths.
