- 191
- 65
- 28
- Austin, TX
I gambled and purchased a non-working M929 and had it towed to the house. The tow company removed both the middle prop shaft (between transfer case and middle axle) and rear prop shaft (between the middle and rear axle) , hoisted the front end off the ground, and used tow truck air to release and operate the brakes for the tow. I reinstalled the middle prop shaft but haven't installed the rear shaft since I need Soldier B and don't have one at the moment. I got the truck running by replacing the rubber fuel lines but need to park it out back for a bit until I have more time for other things like upgrading alternator, rebuilding PCB, etc.
So here's the two part question:
-Can I drive the truck without the rear prop shaft? Mainly for short distances on the road to verify all is working. I think the answer is yes but wanted to verify as it may be a while before I can get a capable Soldier B to help reinstall the rear shaft.
-Can I engage the front axles to make it a 6x4 in high only (not low) so I don't get stuck (or at least get unstuck from where I'm sitting. LOL!) Again, I think the answer is yes but wanted to verify with the expert since I understand there are limitations with being in low gear and backing up. Not sure if there is anything else to be concerned about.
