R & R work (remove and repair)
5,184
I see a pipe wrench in a vise and hands in pockets, must be a pic from Drew's house!!!!!!!!!!!!!!!!!!
No, you see a pipe wrench, clamped in a vise, bolted to a NOS crated deuce t-case, not at Drew's house.
(I have a pipe vise mounted on a work bench here actually)
1,164
That's not really explaining the picture.
OK, fine.
One time, at band camp.....................................
Alright, first............ clintogf bought a bunch of NOS transfers.
http://www.steelsoldiers.com/showthread.php?48432-A-trip-to-Redstone-Arsenal&highlight=
She sold all but 2 of them...... and I said "Honey, if you want me to keep putting up with you, I need one of those for HQ41 and I need another one for HQ43."
So the transfer sits in the garage, awaiting the day the transfer wears out in my '87 M35A2C.
And while it sits there, I need a place for a vice, since I am poor and can not afford to build a shop.
So the vice got mounted to the NOS deuce transfer case crate.
And........ one day, I needed to use the pipe wrench to hold something (one of the studs came out of a front knuckle and I needed to get the nut off the stud). The vice wasn't strong enough to hold the stud without it turning so the pipe wrench came out. And I only have 2 arms so I had to figure out how to hold the pipe wrench while I turned the wrench.
And all of a sudden, in a flash of brilliance I SAW THE VICE AND ALL THE UNICORNS SANG AND I KNEW THAT WAS THE WAY.
The end.
Another Ahab
4,953
Alexandria, VA
The end.
Always love those. They're the best:
1,827
I've said it before, I'll say it again, We need a vise forum for those of us who have a vise vice. One day I'll tell the story of the 3 foot 4 foot pipe wrench.
saddamsnightmare
82
Abilene, Texas
June 29th, 2015.
Gimpyrobb:
You got yourself a great deal, you just have to remember that machine could be 75+ years old, and not all machine owners maintain their equipment properly....,. I would have said disassemble (and diagram) in your garage, then soak the parts in engine cleaner (or better yet, put it through one of those machine shop parts cleaner tanks), then carefully reassemble, noting any wear or defects, and cleaning all machined travelling surfaces (post, mainly) with crocus cloth. Use 90-100 wt gear oil lightly wiped on during reassembly, lubricate and you should be good....
I used to take care of 180 year old machines, you really have no idea what crud looks like until one of them goes under in a brown water river flood......:D
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Kyle, at the time it was friggin COLD out like 7*. I took it apart in the living room on a big piece of cardboard. I did take it down to its individual components and clean everything. The bearings were replaced and it was put back together. It should have another 75-100yrs of good service to give.
Another Ahab
4,953
Alexandria, VA
June 29th, 2015.
Gimpyrobb:
I am not familiar with "crocus cloth", is that kind of like the fine-grit emery cloth plumber's use to prep a joint for solder?
