R6602 vapor lock
Corbittfire
Elkton, MD
I have a 1952 Corbitt / Oren firetruck with the r6602 motor in it. Truck runs well except on really hot days it will vapor lock and shut off. Any fixes for this problem. All help is appreciated.
NDT
5,991
Camp Wood/LC, TX
Reroute the metal fuel lines well away from the manifolds, or put metal shields between manifolds and the lines, or replumb the lines with rubber hose. Kinda embarrassing when this happens in the Fourth of July parade, huh?
308
11
Bear Creek PA
Could you take a picture of the fuel line routing. I am trying to find my old Continental Engine manuals. They are here somewhere. I have a lot of factory manuals and TSBs for old engines.
silverstate55
Unemployable
855
UT
Don't run any fuel that has ethanol in it; it will absorb moisture from the air, which settles at the bottom of your fuel tank & will rust it out. It also contributes to vapor-locking. Look for non-ethanol fuel.
