Radiator Leak
Flea
10
Northeast TN
My radiator has a leak around the top of the vent tube(?) that goes from the top tank to the filler neck.
Any problems in just soldering this? It's a very small leak, and I only noticed it because there was some coolant dripping on the brush guard (one or two drops). I've not noticed it before.
-Flea
FreightTrain
Banned
2,730
13
Gadsden,Al
use the correct solder.Don't just use electrical solder.Don't want to use a metal composit that will cause more corrosion though electrolosis(or how ever you spell it).
Jake0147
Panton, VT
You might or you might not do more harm than good, but if you bugger it all up and have to carry it to a radiator shop, you're not looking at much if any different cost in having them do it either way.
