drjconley
- 0
- 0
- merced, ca
I put in new head gaskets on the multifuel in my m62a2, and when I drive it the temp gauge will go to the upper portion of hot. I pulled the thermostat hopeing that was the problem. With the thermostat the radiator wasn't hot at all, without the thermostat the radiator is warm to the touch, but it is definately not hot. That was after driving it 15 miles pulling a trailer with a tractor on it. When I pull the radiator cap off I dont see any obvious coolant flow even with the thermostat out. Should I order a water pump or should I get a hand held infrared thermometer and get some temps off of different areas of the engine.
Thanks for any help,
Jim Conley
Jim Conley
