Radiator Removal
scjarena
10
Houston, Texas
I'm working on getting my old m211 running again. For removing the radiator, it looks like all there is to do is unbolt fan shroud and it appears the radiator hangs on bracket which go thru to the front there there are "L" shaped slots. Does it just lift out when the bolts in the slots are removed or loosened up? I didn't know if these trucks were originally designed so the radiators could be replaced relatively easily. Thanks
NDT
7,496
Camp Wood/LC, TX
The original intent was that you pull the entire grille/core support/nose as one piece.
