radiator repair
wsucougarx
65
Washington State
Well I decided to change out my hoses today on my '68. I got in a bit of a hurry and completely forgot to put my usual piece of thin plywood in front of the radiator. Well, while I leaned the radiator forward to loosen the fan bolts....it happened:shock: My winch clutch handle lock out bracket worked it's way into the radiator thus causing a 1 mm hole:sad:. The radiator is near new and I know these things can be repair.
My question is would a standard propane torch found at Walmart, flux, and solder be good to go on this repair? What type of solder do I want to look for? I am determined to do this myself. I have some experience soldering electrical connections but nothing like this. Being where I live, the local radiator shops just replace radiators they don't fix ones with holes. Please advise.
ODdave
lansing michigan
pretty shure you want acid core solder & brush on flux (pipe repair kit) Drain it completely and fluch with water. Remember it has to be completley bare copper.
1,171
Personally, I like to use a large soldering iron(not a torch). If you must use a propane torch, I would get/use a soldering iron type tip, so you are NOT using the flame.
You need acid core and flux, found in the plumbing dept.
Gently clean the surrounding area and tin the edge of the hole,then bridge it over with solder. More is not better. Control your heat and location of heat.
Drain the whole radiator.
LV2XLR8
Oliver, B.C., Canada
What he said. I've done it before on a couple of car rads I have and it works beautifully but do use the iron, way easier to isolate your repair.
Bill W
Brooks,Ga
As mentioned above the leadfree acid core solder and flux will do just fine. I think a propane torch will do a better job of pre heating the damaged area and burning off any residual water trapped/left in the bad rad tube
cbvet
20
Northwest (Knox) Indiana
The location of the hole makes a big difference! If it's near the tank you may want to use something hotter than propane, maybe MAPP gas or oxy/acetylene. That way you can heat the affected area more quickly without too much heat spreading to the tank joints.
I've had some success soldering radiators with lead-based solder & suitable flux. I don't know if you can still buy lead-based solder though.
If possible, pinch the hole closed. Then really clean the area around the hole with wire brush, steel wool, emery cloth, etc. Apply flux.
Use a medium flame & keep the torch moving. You can add to the damage if you get it too hot. Not enough heat & the solder won't stick. Too much heat can destroy the metal & the solder will just run off.
If you can find an old radiator or heater core to practice on, that would be great.
As an option you could pinch the hole & add a couple of bottles of Bars Leak sealer. I know a lot of guys won't like that suggestion, but I've had very good luck with it.
Hyenine
Georgia
I've used JB weld for these types of repairs in the past. I have a radiator fixed with it that hasn't leaked for 6 years going. It may not be as good as solder, but it may be another choice.
Bill W
Brooks,Ga
Very good point
Though I doubt the cooling tube would be able to transfer that much heat...however if the leak is a couple of inches from the bottom you could leave enough coolant in the lower tank to dissipate any excess heat so it doesn't melt the tank seams
wsucougarx
65
Washington State
Thanks for all your recommendations and advice guys. The holes are about 6-8 inches up from the bottom of the radiator in the vertical cooling passageway. Both are about 1 mm each. Luckily I only got the one passage way. I'm really kicking myself now because I thought about the plywood cover only minutes before it happened. Oh well, live and learn.
jollygreen
Highrige MO
Lol in a pinch to get home I have used and egg and a can of pepper and it still don't leak lol and it smells like your cookin steaks but that ain't no permanent solution just something to keep in mind and to keep ready if the need should arise hahahahahaha!;-)
1,171
I would not try silver soldering it. I would use acid core 95/5 solder.
I don't think that soldering gun is going to do it. The Iron I use (not sure of the wattage) has a tip that is about 3/8" dia. It's a big one.
It wont hurt to try your gun. You may be able to get the hole soldered with it.
1,171
Soft solder, average melt temp, 370F
Hard solder(Silversolder) average melt temp, 850F.
No need to try to silver solder the core.
