Radiator Support Bushing, OEM Part #6264100
Trailhead 4x4
Cleveland, Ohio
if anybody is looking for new radiator isolators, I got a set by Prothane from Summit Racing, part# 7-1712, they work great. Originals are no longer available apparently.
1,170
How about puting the OEM number in this thread and or title so it helps people when they search?
1,170
How did you determine that originals are no longer available, if you don't have the part number(found in the -20P or -34P)?
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
The part has indeed been discontinued...GMpartsdirect.com
As you can see I edited the title to reflect the EOM Part Number for future searches. And if you simply Google the EOM part #, you'll see that a reproduction replacement part is available at Summit as well as Jegs and probably several other places as well.
1,170
A search for the number on this site, will pull up a couple threads too.
As a general rule, finding the part in the TM and searching this site and google will usually help fast and easy.
We all call parts different names(often wrong or differing because of dialect), but part numbers are easy to use and universal.
Trailhead 4x4
Cleveland, Ohio
I just took my old ones to the dealer parts counter and asked the guy to look them up, he said they are no longer available. Just when I was about to give up, I happened across the Prothane ones, they worked great.
