Radio Cable Routing Questions
Mogman
10,584
Papalote, TX
They may be cut under the insulation mat before they come out and join the power cables behind the doghouse, those might be coax for the radios.
BadAmish
72
Grants Pass, Oregon
Is this the shunt?
I forgot that I have a borescope that I got a few years ago to look inside a wall to see where some wires were going. I am charging it and, weather permitting, see if I can see what is going on inside that channel.
BadAmish
72
Grants Pass, Oregon
Using the borescope I was able to see the hangup and removed several cables. There is one large diameter cable and one smaller one. I think I will be able to remove the smaller one and it looks like the larger diameter one may turn towards the firewall. I got tired and sleepy from our big BBQ lunch/dinner so I will follow up on the remaining cables in a day or two.
Here is two I was able to pull through that channel:
