Radio shelf mounting holes
ryanruck
Cincinnati, OH
You can try compressing them further so they grab onto the metal they're installed in a little better.
If you don't want to spend the money on a full size rivnut tool (which I recommend, very handy!), you can just get a manual rivnut tool that's good for doing ones or twos (just find the size you need, they're linked in the "Frequently Bought Together" section).
Retiredwarhorses
3,884
Brentwood, Calif
Which ones? The 4 in the deck or the 2 on the dash? Either way, they aren't conventional rivnuts...not sure what they are called, but they are pressed and crimped form the sides at like 3 or 4 points, they are a real PITA once they fail.
papakb
1,186
San Jose, Ca
The deck plate is a separate piece that attaches from below the deck. The 2 on the duct can be replaced 2 ways. Either punch out the old ones and leave the bits and pieces in the duct and install 5/16 rivnuts/nutserts in their place or remove the duct and replace the 1/4-20 rivnuts that are in it.
Kurt
KG6KMJ
