rails up resto in picture form
Lindsaym151
12
Eustis,FL.
IMG_0288.jpgIMG_0297.jpgIMG_0296.jpgIMG_0295.jpgIMG_0294.jpgIMG_0292.jpgIMG_0291.jpgIMG_0290.jpgIMG_0289.jpgIMG_0298.jpgOK, had a day come to me, worked on the front floor pan and the riser between the gas compartment.
This is an important piece!
you have to line up your seat frame, get your squared corners, and lengths to your new side pieces , all at the same time!!!!
This took me 3 hrs, checking and 2 nd , and checking it one more time!!!
Also worked on the gas tank compartment! Equally as exasperating!. Measuring, 3 times, and then cutting!
TOTAL LABOR TIME 7 HRS
Lindsaym151
12
Eustis,FL.
We Will back at it tomorrow!
Going to get the gas compartment completed!
Will be posting very important measurements and welding tips I think can help!
Lindsaym151
12
Eustis,FL.
IMG_0362.jpgIMG_0369.jpgIMG_0368.jpgIMG_0367.jpgIMG_0366.jpgIMG_0365.jpgIMG_0364.jpgIMG_0363.jpgIMG_0361.jpgIMG_0370.jpgHey everyone,
I'm back! Had a family emergency out of state and the holidays!
Well got the gas tank floor in, sides of vehicle off and under body kit installed over the last few days
Also Guy Loomis called yesterday , he was in town and wanted to check out my progress.
Spent a couple hours going over the project and then put 50 miles off-road with a couple other 151"s that I have.
Thanks Guy for all your advice and helpful hints to move this build forward!
I found two full side panels buried in the warehouse the other day! (old Florida tactical pieces) They are a close match, not correct rolled bends on the edges(I will take pics tomorrow) .
They will work fine for this project though!
Lindsaym151
12
Eustis,FL.
Lets do some math and time sheets, and consumables reports
Cut off wheels,100@ 6.00 per pack of 10. =60.00
24 grit grinding wheels,20 @10.00 per pack of 10.=40.00
80 grit flap grinding wheels,4@ 7.00 ea =28.00
Auto body seam caulk 4 tubes @ 12.00 ea=48.00
CMD Panels Figure every one he has , times 2 = 1700.00
cost of M151 1 @ 3800.00(PAYED WAY TO MUCH!!!)
60 man hours @ (CONSERVITAVE) 50.0=1100.00
total to date
6776.00
Tuition at a technical school way more than that ! to learn how to fabricate and learn how to weld! All hours have been weekends and after working hours.
Lindsaym151
12
Eustis,FL.
Dry fit new side panels today!
To cold to work in metal shed today!
I will be installing all the floor pans and compartment dividers before I tack up the side panels!IMG_0376.jpgIMG_0375.jpgIMG_0382.jpgIMG_0381.jpgIMG_0380.jpgIMG_0379.jpgIMG_0378.jpgIMG_0377.jpg
Lindsaym151
12
Eustis,FL.
These pics are the 1st go around! I have replaced all this work ! I wasn't happy with it!
Been just to cold and windy here to get any kind of quality work done!Im waiting a few more days (back in the 70's on Sunday) Will give it another shot then!
NDT
7,440
Camp Wood/LC, TX
Rails up?, now you are replacing the rails too. (LOL) The saying is in the restoration biz "The only part of the car I could use was the shadow".
Lindsaym151
12
Eustis,FL.
Got the new rails in today!
Also got the tool box floor in and battery box floor! I am planning on using body seam caulk fairly heavy on the underside to insure rust wont be an issue for the new owner!
And yes it will be for sale at the completion of the project!
If your interested in purchasing it ,PM me
Lindsaym151
12
Eustis,FL.
IMG_0391.jpgIMG_0400.jpgIMG_0399.jpgIMG_0398.jpgIMG_0397.jpgIMG_0395.jpgIMG_0394.jpgIMG_0393.jpgIMG_0392.jpgIMG_0401.jpgWell I had to work on daughters car today!(heater core , back flush and flush out cooling system!)
Got to play around with my side panels! Heres a bunch of pics!
Lindsaym151
12
Eustis,FL.
IMG_0390.jpgIMG_0384.jpgIMG_0383.jpgIMG_0389.jpgIMG_0387.jpgmore pics, That's going to do it for today!
I will be putting in around 5 hrs on her tomorrow!
Thank god its going to be warmer tomorrow!:):):):):):):clinto:
Lindsaym151
12
Eustis,FL.
IMG_0424.jpgIMG_0422.jpgIMG_0423.jpgIMG_0415.jpgIMG_0416.jpgIMG_0417.jpgIMG_0418.jpgIMG_0419.jpgIMG_0420.jpgIMG_0421.jpgToday we managed to get the drivers side panel completed!
I opted to do any body work on this panel before I mounted it!
Sure doesn't look like I did much! took 6 hrs .
Fabricated both lower corners and axe cut out and apron around axe cut out.
A lot of grinding ,body filler sanding and d-a sanding the metal!
I will be priming this part before attaching it!
Lindsaym151
12
Eustis,FL.
Well so much for constructive criticism,
Just got off the phone with my brother in law(NUCULAR CERT> WELDER) laughing his ass off over my welding skills!
I have to go back and check every weld! That's gonna take a few days! Also reminded me about my copper plate he sent me for thin welds!
nattieleather
148
Cleveland, OH
I wouldn't worry about your brother. I'm no expert but they look as good as the factory ones I've seen over the years. You shouldn't have any problems. :)
F18hornetM
11
Ocean City, Md
I am sure he is trying to be helpful but Nuclear welding and auto body welding are to very different specs. I seriously doubt he has very much rusty sheet metal to weld in the plant LOL. Great job on the project!!!
