Random maintenance tip - crud at the bottom of the pop-out cab air vent
cattlerepairman
3,201
NORTH (Canada)
Just spent half an hour trying to fish the door opening limiter rod out of the hollow area where the pop-out cab vent sits. I was surprised how much crud and leaves and general dirt collects in there.
Open the vent, grab the spring from the outside and gently push it down and in to unhook it, so the vent door opens further. Loosen crud at the bottom of the hollow space with a screwdriver and shopvac it out until you can see the drain hole in the bottom - that could save that cab corner from rusting through from the inside!
Menaces Nemesis
"Little Black Truck" Conservator
261
Denver, Colorado
When I cleaned mine out, along with all the compost, and rodent-nesting-type material, I found a bonus door limiter and rubber absorber cushion at the bottom of both pockets that someone at some time had dropped down there, and instead of fishing them out, they just replaced the parts!
