Random Oil Leaking From Rear Wheel
Jbulach
2,410
Sunman Indiana
If your dealing with a dual wheel setup, Until you can find or afford a dolly, get a gallon of tire mounting lubricant from Napa, spread a little on the floor or on a white poly mudflap, underneath the wheels and they will slide right off slick as butter, hub and all. No lifting necessary. Jack the axle up just enough to get the tires barely off the ground
M925A2 with dump hoist
