Really frustrated. .M1010 and questionable work
infidel got me
33
Newberry, Florida
3 brand new glow plugs were bad...meaning they left it in run without starting engine....
They can't duplicate the surging but it happened 30 seconds after leaving...sigh....
They tried to bill me for it...I about lost it...
I had a huge post written but my battery died and...poof..
When I get on my laptop I'll go into more detail.
Just lick your wounds,and find another shop.Ask at your local parts store.
Napa,car quest or a truck stop.Someone fixes em right in WA.
GOOD LUCK
Skinny
498
Portsmouth, NH
The shop really messed up not contacting you after going over the estimate. True, book time is never accurate especially on older trucks. Yes, I'd charge you double if I ran into a problem fixing your truck. It is YOUR truck...I don't own it nor did I design it. But a good shop will communicate with you at every major step of the repair.
These things are 30 years old, you are going to pay a LOT of money to someone getting it to a reliable point. If you can't do the repairs for whatever reason, buckle up because your truck is about to take you for a ride.
I would step back and evaluate if this thing is what you want or are looking for. Pretty much everything can be done by a novice with some time and tools but if you don't have the capacity then your only option is to write checks. I hope you find a shop that is courteous and willing to work with you.
MarcusOReallyus
820
Virginia
As a shop owner I would like to point out that an estimate is just that. An estimate!! Now if that was my shop I would be embarrassed to be that far
out on an estimate and I certainly wouldn't proceed with the job without discussing the matter with the customer. As for putting the head on and off a few
times that is the shop's problem and at my shop we would eat that labour. My customers don't pay for our mistakes and that is what has kept me in business for
fourty four years. I would try to sit down with the shop owner and talk this over. Something at his shop is definitely wrong. Good luck.
Barry
That's the way it's supposed to be. My mistake, I eat it. Your mistake, you eat it. Seems simple enough to me.
:beer:
I dropped a shop for exactly that reason, and will every time.
TechnoWeenie
1,805
Nova Laboratories, WA
Can't believe I didn't update this a decade ago....
Shop is H&H Diesel.
The guy they had working on my truck was a new guy, and he actually came to me when I came to pick up the truck, after I paid. He explained they put him on it, KNOWING he didn't know anything about it, as a 'here, go figure out how to do this, it's OK to screw it up, we don't care if we lose him as a customer' kind of thing. They used my truck for him to practice on. He actually said he felt bad because all the extra charges that were added were his fault - he broke BRAND NEW HEAD BOLTS which had to be drilled out, and the shop blamed 'old engine' for the labor and billed me. He didn't know anything about diesel engines and the DOZENS of hours of added labor were because he was going very slow and making mistakes that had to be fixed.
I mentioned before they burned out 3 glow plugs. It wasn't 3 - it was ALL 8. They had left the truck on the 'ignition' position and they glow plug module didn't shut off so it just burned out all the BRAND NEW PLUGS - and DESTROYED BOTH BRAND NEW BATTERIES.. Now, luckily the batteries I had just bought from Costco and was able to warranty swap them, and the plugs were also covered, but they flat out said they wanted to charge me for replacing them aftr THEY messed up.
So, I put my foot down and they end up replacing.. .some of them... after they told me they replaced all of them.. .but now the cold advance doesn't work... I go look in the glove box and there are a couple of brand new glow plugs... sitting in their box... when I called them on them not installing all new glow plugs they said they weren't going to because they were too hard to get to. THEN when I went to go check on the cold advance issue I noticed they put the glow plug wire on the temp sensor, and the temp sensor wire on the glow plug. Of course, sending voltage through a temp sensor toasted it - they refused to replace it claiming it's not their fault.
I ended up paying over $5k (I think it was closer to $6K) when all was said and done - for what was a head replacement, an IP, and bleeding injectors/lines. Oh, and the IP 'failed' while in their care/custody, while they were working on it.. .How convenient! After the head was 'fixed' and banging/clanking, and I brought it back to them, they said they couldn't fix it properly because the IP had failed and it wouldn't even start. They told me I could either pay to replace the pump or they'd toss all the parts in the back and I can call a tow truck to come get it. Yeah, they actually said that. They blamed them not installing a head properly on a 'broken IP' - Keep in mind I think it had either 19 or 20K on it at the time....
I ended up selling it instead of keeping it because every time I looked at it I got mad and dreaded going to start it or drive it and end up stuck on the side of the road.. .with only 22K miles on it... It was reliable after having them fix things half a dozen times - but there was that nagging in the back of my mind questioning everything and wondering what was missed - even if it was running fine then.
I don't have enough cuss words for them. If you look at Google reviews you'll see a bunch of people just like me. Very few places I actually wish ill will on but if that place went up in a ball of flames I'd probably smile and have a beer... AND I DON'T EVEN DRINK! :ROFLMAO:
The fact that an EMPLOYEE has to come to me and tell me he feels bad because they essentially used him to overbill me, intentionally, then refuse to fully fix their mistakes, is absolutely insane.
CARC686
708
New Mexico
Shop is H&H Diesel.
Refer to my sig.
CARC686
708
New Mexico
Sorry. My response was pithy. Basically, these modern diesel shops know how to make more horsepower with a few platforms. They advertise themselves as diesel shops because they know how to mess with Duramax, Powerstroke, and Cummins engines. That has its place, but the CUCV ain't it. You're an oddball and they wanted to get rid of you. You shouldn't trust your CUCV with a modern diesel shop. You would probably be better off with a classic restomod shop, but you don't own a CUCV because you're rich, so the best bet is to figure it out yourself. It's a pain, but it's the best course of action. By the time you're done with any given thing under the hood, you'll find you've saved at least $500 and probably more than $1000 for your trouble.
TechnoWeenie
1,805
At the time, I was working 60-80 hour weeks, I can't remember exactly but I had either just started living in it or had already given notice to my landlord that I was going to be moving out, so I didn't have time, or energy, to deal with it.
