That's my thought so far, with my limited knowledge of applications and various types. Removing the inter-axle driveshaft is the cheapest, but not convenient if you ever want all the wheels to drive, and also the walking suspension would tend to unload the front axle as forward torque is appled. Better is to drive the rear rear only, which is the next cheapest option, the lockout hub option. That would allow the rear rear to be driven and the front rear to idle, which (in coming from me is according to theory and second hand reports only) would provide better tire wear and general drivability, along with being very convenient to "lock in" the idle axle when needed.
So, IMO only, a disconnectable inter-axle driveshaft would be more expensive and less effective (equivalent to removing the driveshaft), and less desirable (from an operational point of view) than the single lockout hub on the front rear.
I am intrigued by the sprague idea, depending how it works. If it could pick and choose WHICH rear to drive on an as needed basis (as opposed to always driving one and selecting the other as needed), it might be almost as effective as modern stuff. Since it would tend to always drive the "biggest" set of wheels as the tread wears off, it'd probably (disclaimer again, theory only), but probably do a pretty good job equalizing the tire wear if all the tires are not identical.
I'm working on a wait and see basis, I know I'd like to drive mine more than I will, so while an actual power divider (inter-axle differential) would be nice, I'm thinking if I end up needing a solution it'll probably be the single lockout hub. Very easy to do, fairly convenient to operate, and zero perminant modifications, and un-modifying it for authenticity purposes should I decide to would just take a few minutes and a couple of hand tools.
