Rear axle oil seal
4,626
IMG tags are intentionally set to not embed to promote users to host the images from the site.
(ouch, that hurt, some of you will understand that)
If you want to repair it properly, you need an axle gasket. But I've cleaned the mating surfaces and silicone'd them up many many times and on multiple vehicles.
Sam27
Tucson
Thanks. Can you explain where the gasket goes? I'm sure I'll find it, but I'd like to understand ahead of time. I haven't found a good exploded view in the manuals yet. Is a gasket obtainable at the corner parts store?
4,626
Take the 8 bolts holding the axle in place out, slide the axle out. It will likely be in 6 or 7 parts between the inside of the axle shaft flange and the wheel hub. Clean it down with a gasket scraper until you're at bare metal. The gaskets usually aren't in stock in my experience. That's why I just go with the silicone.
Warthog
227
OKC, OK
TM 9-2320-289-20
Chapter 6-8, page 6-15. Has detailed instructions with pictures on the axle shafts.
I would just use some RTV sealer instead of a gasket.
Sam27
Tucson
Oh! So it's purely a seal between the axleshaft itself and the hub. I was thinking it would be more internal. I have gasket material I could attempt to create a gasket... anyway, this is really straightforward. Thanks for the help.
Cucvnut
51
Carver, Oregon
super easy to change. will take you about a half an hour. Just make sure you don't let a lot of oil spill out of the axle tube when you change it.
kassim503
Stony Brook, NY
Make sure you leave the truck in neutral when you change it, and chock the wheels. I usually rtv them as well. While you are in there its always strongly suggested that you jack up the side, and check for play in the wheel bearing, b/c play doesnt really show until the shaft is off.
