Rear axle seal replacement
I just got my duece registered (finally!!) :) :) and now it is time to drive the snot out of it. I thought it was a '71 but the gal at the counter put a call in and said it was a '73. So yay!
Now, only one problem, I just noticed that the inside of my left front duals is leaking gear oil. It happened on my last drive (those trip permits were getting pricey every week!), and it is spraying the underside of the bed. Dang!! :x :x Not real bad but "it just ain't kosher" that way.
I did a search on the subject and came up with the following advice.
http://www.steelsoldiers.com/index....e=viewtopic&t=173&highlight=deuce+tips+tricks
I checked out Saturn Surplus and they show an axle seal and also a gasket.
Is this correct? One of each needed?
If anyone has any more input or parts I need please let me know.
Oh by the way, I have read about cleaning the "vents" on these axles to make sure that the seals don't blow from pressure. I know it wasn't a long enough drive to get really warm but what do I know. :?
Where is the vent(s) and how do you clean them?
Thanks for any advice
ken
27
Houston Texas
The vents are in two different places, depending on the year the axle was made. The older ones are on the axle square tube, pointing up at the bed. The newer ones are on the side inspection plate where the pinion shaft goes through the diff. Call bret at boyce equipment. He has the axle seal kit with every thing you need to ghange the wheel seals. Don't forget the wheel bearings are sopposed to ride in grease. Getting gear oil on them won't hurt, but enough will wash the grease off of the bearings. And if enough oil isn't present it will burn up the bearings. These seals usally start to leak when the bearings go bad. I sudjest you check all the wheel bearings.
ken
27
Houston Texas
When you jack up the suspected wheel, try to rock the wheel up and down on the spindle. If you feel movement it's probally shot. After dissembly wash the bearings in solvent. If they are discolored "purple or a shade of blue" then they are no good. If any rust is present replace them also. It's not difficult, but eat a good breakfast, the parts are heavy. Also after you take the outer seal off there is a small piece of cork in the keyway. Don't loose it, you will need it.
red devils dude
Ft Campbell
ken said Also after you take the outer seal off there is a small piece of cork in the keyway. Don't loose it, you will need it.
you can make a new one from a chevy 350 valve cover gasket.
ken
27
Houston Texas
Yea you can make a new one. It looks like a wedge. You'll need a REALLY SHARP knife to keep the cork from tearing. Watch your fingers!!!!
dozer1
13
Sargeant, Minnesota
Can anybody tell me what the proper method of setting the wheel bearing tighness is? I know it is in a TM but have yet
th DL them. If nessesary I will do so tonight. thanks
