- 9,604
- 1,487
- 113
- mid- michigan
Well by your own statement you DID NOT REPLACE the rubber lines , brake shoes/pads or drums/rotors so no everything wasn't replaced .No fudging here. I said I replaced the wheel cylinders earlier, all brake components were replaced except for the proportioning valve and lines (which were all cleaned individually as I said) the only think I did was adjust the brake shoes after putting it all back together as I thought there could have had a little better tolerance. Everything about that parking brake was for sure installed correctly. I took pictures before and after to make sure too. It scouts Honor was installed exactly correctly. I did not get the drums turned or replaced. If I have time I can try to use a dial indicator on it to see if it's out of round. I want to be clear that it's more or less the rear just locks up a little earlier than before. Nothing unsafe per se. The front pads are clean as a whistle, no oil, no nothing. I used a shop manual for everything with pictures just to make sure. I do not mean to come off as hard headed but I am 100% sure of the work I did. There are only two things that changed. Whether or not the proportioning valve is the culprit, or the tight brake shoes adjustment. I can see if I can get the rear drums turned or replaced, although it would be shocking that it would suddenly change what's been happening. You know what I mean?
As was already pointed out several out of round / warped drums/rotors brake linings with uneven hardness due to heat or worn out soft rubber brake lines expanding under pressure now that it has good springs and wheel cylinders in the back.
You did half a brake job and don't want to listen to anybody else so why even bother posting the question when your mind is made up on the answer.
