rear brake metal line
ajg6989
New Smyrna Beach, FL
Who has the rear metal brake tube assembly part # 752934 nsn 4710-00-752-9374. Or do I just take it to a hose place somewhere and have it made. The end that attaches to the brass piece between the rear axles is leaking right where it is supposed to spin on to the brass piece.
comdiver
Buffalo NY
I made mine. I started with a roll of tubing and some flare nuts. You will need a tubing bender, a double flare tool and a tube cutter. You can also buy tube with ends already on it, but you need to deal with the stock lenghts.
ajg6989
got it done today went to auto zone got a 5/16 6" section and a 3' section and a brass joiner. then the door stop rolling up so now I need a new deuce door or take out.
