Rear bumper pictures
Economist
Arizona
That order may help resolve my issues fitting the inner braces. I did get the Rhino tire carrier mounted, but I am waiting on the mud flaps. I may just loosen everything up a bit and try to squeeze the inner braces in once the mud flaps arrive. I had no luck getting the inner braces on, regardless of the status of the pintle hitch. It makes sense that the entire bumper needs to move out a bit to accommodate.
Best Regards,
-Economist.
TedG
MI USA
There are several inner braces that have been made. Only one fits this application. I have an unmounted one at home and I will snap a picture of it with a tape measure.
Economist
Arizona
Any luck on tracking down the braces? I am thinking I will mill mine down to fit. The braces are very thick and quite close to fitting in.
Economist
Arizona
Ted,
If there was a patron saint of HMMWV restoration, it would have to be you. Many thanks. I will measure mine and let you know the results. Have a great weekend!
-Economist.
Economist
Arizona
My brackets appear to be identical to the photos. I will try to loosen up the fittings first and then resort to a little tolerance milling to get it in. Thanks again.
foxtrot
3,258
france
The -24P is very good to look at.
Here is a setup prior to painting. Bumpers are cheap and easy to find, all the brackets take time and $. Good luck!
Hello,
TedG.
Looking at your photo :popcorn: it seems to me your left front and rear tires are mounted upside down.
TedG
MI USA
Funny foxtrot! Tell that to the inspector of these M1114's being delivered to in Iraq! lol
The supplier mounts all tires the same on the rims. Yes, the tread is technically backwards but it is easier to have one setup as opposed to several. Some of the civi owners of hmmwv's will change the tire on the rim but I am lazy and install only new sets the same as the supplier.
Thanks.
