rear diff oil seal?
Patattack
Westminster, md
quick ? my rear diff oil seal is leaking, do i order the seal off a k10 3/4 ton cuz the civi blazer is 1/2 ton, its sounds like a stupid ?, but i just want to make sure, thanks
OL AG '89
9
Kingwood, Texas
The M1009 has Corporate 10 bolt axles front and rear with 3.08 gear ratio and a Gov-Lok in the rear. The front axle is open.
Straight from the WIKI page
Cucvnut
61
Carver, Oregon
looks like you might need the
Differential Bearing/Seal Kit-Front.
Can you take some pictures so we can be sure that's what you need ?
344lbsofgetdown
NEWARK Ohio
if u need the diff cover seal all u need to know is its 10 bolt any parts guy that is good at what he does will find it i changed mine dont like the gasket so i use the right stuff
JUNKYARDJOHN
somerset ky
yea the back were the driveshaft connects to, i hate using rtv, but if i cant find it i guess ill have to.
Any pinion seal for a 10 bolt g.m. corp. will work. The only difference between 10 bolt 1/2 & 3/4 tons are the hubs. (8 lug vs. 6 lug) . The M1009s & civi. blazers are the same except for the spring pack. RTV will not work on a pinion seal, but they seal up a rear cover just fine instead of a gasket. 2cents John (I think you guys are confusing seals with gaskets)
Warthog
231
OKC, OK
Just go to any parts store and ask for parts for a military vehicle. They will be more than happy to help you. ;-);-);-)
First off, NEVER assume we know what truck you are talking about. List the type of vehicle.
If you would take old advice and LOOK at the parts manuals, you will find 99% of all the GM part numbers you will every need.
Don't know what the part is called? Look thru the parts manual untill you find the picture of the part, then see what it is called and the associated part number.
Take those numbers, google them and you will find your parts.
NAPA will even list the interchange numbers.
Not that hard, just takes some effort.
From the TM 9-2320-289-34P parts manual, Figure 112, Item #4 the GM part number for the rear Pinion Oil Seal for the M1009 is:
GM 1243465
Plugging that into NAPAs parts interchange it shows:
NOS 19273
WOW!!! Amazing how that works.
Patattack
Westminster, md
CAIM DOWN warthog im just asking a simple question. im new at this ok im used to putting nsn on paper or ordering parts for civi trucks. i didnt know u could do that, thanks for pointing that out for future references,:smile:
OL AG '89
9
Kingwood, Texas
WOW..... not making friends with a response like that....
If you are used to ordering parts for Civy trucks, then pretend the TM -34P is your parts ordering book.
READ THE BOOK!!!!
then ask questions!!!!
Do you have a copy of the -34P?
