rear drum brakes 1009
rsh4364
15
greensprings ,ohio
Happy Thanksgiving All,Im gearing up to redo rear brakes,going with new wheel cyls. all in one drumrepair kit,new shoes,new self adj. kit and new rear brake lines.I know when I got new tires the guys couldn't get the wheels off and I had to buy new wheels they were bent so bad,Do you think drums will come off any easier ?
Warthog
231
OKC, OK
Maybe you should first take your truck to a brake place for a "free" inspection. ;-)
Stuck drums can be a bear to get off.
scottladdy
CT
Don't forget to loosen the shoes. Procedure is simple. Special drum brake tools help a bit, but can be done with a screwdriver.
The shoes don't span the entire width of the braking surface of the drum. There is usually about a 1/8" gap. Often times the drums will develop rust in this area, making it nearly impossible to remove the drum unless you loosen the adjuster a significant amount.
I always recommend replacing the hardware as well. All springs, self adjuster, and parking brake hardware. Very inexpensive (maybe $15 per axle at RockAuto).
