Rear Energy Suspension bushing # ?
ezgn
1,039
Lake Elsinore Ca.
Does anyone know the correct Energy Suspension rear polyurethane bushing number replacement kit for a M1008?
ezgn
1,039
Lake Elsinore Ca.
Thanks, I have checked the measurements the best I can. I thought the front rear spring was 1"3/4 the rear spring 1"1/2 and the bottom shackle 1"3/8, I must be wrong because I can't find the kit with these measurements. My measurements might be off. I will try again.
ezgn
1,039
Lake Elsinore Ca.
I re-measured and I checked the manual. The rear shackle bushings take the same bushings. So it is either 1"1/2 or 1"3/8. CUCVRUS remembers them to be 1"3/8. I Think he is right. He has changed allot of them and my second measurement seems to confirm this. Any one else have any other thoughts would be great. Thanks.
cucvrus
9,673
Jonestown Pennsylvania
They are not a bank breaking item. But if they are wrong return them. Are you trying to change all the bushings? That would be why I would just buy the kit I mentioned. The shackles may not come with the kit but I think I have steered you in the right direction.
Mad Texan
1,150
Chester County, PA
When I ordered from ORD for my springs.... can't say for the shackle because I replaced it and it already went to the scrap yard.
(GU38001-B) Greasable Bushing, Bolt, & Sleeve Kit for both spring eyes of GM Rear Springs - 1.75" and 1.5" eye sizes
ezgn
1,039
Lake Elsinore Ca.
Did you install them yet? Would like to know if they fit. I'm about to place an order for my mate.
Read my post on the right Energy Suspension Bushings. It will give you all the correct information for stock springs. Mine is a 1986 M1008
