2deuce
- 182
- 63
- portland, oregon
I'm doing a rear brake job as the seal leaked oil onto the brakes. After pulling everything apart I can only find an outer hub seal and that is all that the tm shows unless I'm missing it. How is oil kept out of the hub bearings? When I took this apart oil poured out of the hub. There was no grease in there. Looks like that is the design and if so that seal has a harder job to do than I expected. If there was a seal on the axle shaft, that oil could be kept out and grease would be used on the bearings. I better check the breather to make sure that is clear too. I'm replacing the shoes on the other side next so I'll check the oil situation there soon. This just didn't look right to me, I'm more familiar with older trucks that have 2 seals sealing each hub.
This hub has been apart before, possibly for the same leaking problem. Someone had massed silicone on the axle on the inside of the axle flange. Looks like that didn't have much chance to work, but I'm wondering is there is another solution?
Thanks
Thanks
