Rear Main
Ord22
Stockbridge, Ga
for one thing. the rear main seal should be tight and not pushed in by hand. when you said that you can push it in by hand, its too loose. when installing them, you will need something like the old seal over the new seal to put it in, tapping lightly with hammer. do not put any sealant on it, its not needed! you need the correct seal.
buddy_holly
Tucson, AZ
I'm having a similar issue with a leaky rear main seal and I'm trying to find all the specs for the clearances, crankshaft end play, etc. so I'll be able to check everything/replace anything once the tranny and the bottom half of the engine are apart. Where can this info be found? I've been digging through my TM discs for a couple hours now and I think my eyes are gonna go buggy if I look at one more dang PDF file. Thanks to anyone who can help point me in the right direction. :shock:
plym49
171
TX USA
Whats a "speedi-sleeve"?
A thin, purpose-built, thin sleeve of metal. It presses over the part that has a groove worn into it by the seal (in this case, your crank) and provides a brand-new, smooth surface for the new seal to ride on. This way you make up for wear, plus any new wear is on the sleeve and not your expensive crank. Speedi-sleeves are usually designed for particular applications and will include any shoulders, etc. that are needed. They install with a clever little tool that is included in the package. Old sleeves are easily peeled off and replaced with no damage to the part in question. I use them as a matter of course on front seal replacements and the like as there is almost always a tiny groove and this way you always start fresh. The sleeves are so thin that the regular seal still works.
Random Tech Tip #38,2012. Got an oil leak you can't seem to find the souce for?
Here's an old trick for finding those pesky oil leaks. I read about this method several years ago in Easyriders Magazine and was originally used to find slow seeping seals and gaskets on an american made V-twin, but there's no reason you can't use it on anything that holds oil, has gaskets and shouldn't leak. After you spray the brake cleaner around and get everything all clean and sanitary, give it a little drying time and give the suspect area a coat of spray-powder deoderant. Once you get a fair coat of the white stuff all around, just run the engine a little bit and any leak even down to the slowest seep will stick out like a seagull at an Adam Sandler movie! (old Family Guy reference)
All bad similies aside, there's not an oil leak that can hide from this leak-finder method and will tell you exactly what's leaking and how bad. [thumbzup]
plym49
171
TX USA
Good tip! Although I was taught that a slow seeping oil leak on a Harley was when you knew it was out of oil.
crazywelder72
Winchester Ma
Dose anyone have a p/n for the sleeve for the deuce? IS this something that is bought at napa?
crazywelder72
Winchester Ma
The p/n is 99499 and I found the best deal online at Advanced Auto Parts. They were $65 and there was a 15% discount coupon for online ordering. It gets better though. If you build your order over $75, you get free shipping. They just happen to have the 3" sockets for the axle nuts.
