patr
- 0
- 0
- Noblesville, IN
I have an M35A2 coming, and we mow about 100 acres of grass around our two airports that I work at. Is there a way to run a 540rpm PTO from the rear of the Duece to power a large bat-wing mower?
m-35tom said:yes, tow a tractor behind it..................
BTW I don't think I would try this at homeBFR said:well... you could make up a flange that bolts to the pinion on the rear most axle...
Close...check and see what the HP required is for the mower. You may be better off mounting a small engine to it and dedicating it. You'll still need hyd to fold and not sure how you will tow it. If it's a single pin great. If it's 3 point back to the drawing board. The problem you mmight have with hydraulics is keeping the engine rpm high enough to get the flow but still maintaining drivability. I have a similar problem with my farmall cub. PTO on the back side of the clutch which means everytime I use the clutch the mower is disconnected. I'm going to use a seperate gas engine to drive the mower.m-35tom said:yes, tow a tractor behind it..................
Or an Agri-Jeep!MB4/94 said:Sounds like you should have got a Unimog instead of a deuce.
