Rear Mounted Winch?
Luke
Wichita, Kansas
Anyone have a good setup for a rear mounted winch? I don't have a truck yet but would like a bobbed truck with pto winch up front, and some sort of winch on the back. I don't know about getting an electric winch, but was wondering if anyone knew of a dedicated engine driven winch? I am invisioning something like the front winch but powered by a dedicated Honda gasoline engine like used on lawnmowers or powerwashers. Does anyone know of a winch made to be paired to a motor like this?
I would love to have a class 5 reciever mounted on the rear of the deuce, with the crazy winch setup I am thinking of attached to it unless i need to tow something.
While I am sure it would be impractical to try and connect an actual deuce winch to a little motor, I am hoping someone knows of a commercial solution that is made for this. With my photo editing skills I have come up with a picture of what I invision.
rchalmers3
30
Irmo, South Carolina
i want to mount the hydralic winch from a bridge truck, in the frame at the back of a 5 ton and run the hydralics off the pto as was done on the 5 ton bridge truck
I agree: running hydraulics opens up all kinds of possibilities for powering winches and other equipment. If I owned one truck and was going to keep it awhile, that is how I'd modify it.
Why not consider an electric winch? The power cables can be permanently mounted with connectors at the rear of the frame. This way you can create the same solution as the gas powered winch being considered, but with less expense and no gas motor care and feeding.
Warn and Milemarker have big 24v winches that could be used for self recovery, using at least one snatch block.
Rick
rmgill
14
Decatur, Ga
If you have a front mounted winch, flip the PTO to power the Hydraulic pump. Then adapt the front winch to take a hydraulic motor and mount your rear winch. You'll be able to power both with hydraulics....
signman48625
barryton,mich
Find a telpohne truck with the rear winch set up off the t-case, it is a slick set up, you can also run a sort set of jin-poles for some interesting pules and lifting.
mudguppy
15
duncan, sc
i have a MileMarker SI12000 24V mounted in the rear of my deuce - works great, just relatively slow (not compared to other electric winches, just to the PTO winch). after i get the engine swap finished, i will be converting the front PTO to hydraulic drive - i have the hydraulic PTO, pump, motor, valving, and lines already spec'd and engineered.
once that's dialed in, i plan to drop another PTO winch in the rear frame and tie that into the hydo' system as well.
just...... need........ time. :roll:
dc3coyote
19
Chattanooga TN
Hydraulic PTO and twin Hydraulic winches, would be the route I would go. Otherwise check out some of the Tatras. they have a mid mounted winch with a pully hook in the rear and the bitter end going to the front. Sorry if this does not make much sence, rough few days.
rwoods
Greeneville/TN
"While I am sure it would be impractical to try and connect an actual deuce winch to a little motor, I am hoping someone knows of a commercial solution that is made for this."
Try this: Ron
12,000 lbs - Hitch Mounted Winch
Self contained vehicle mounted gas winch
popacom
9
winchester,ky
Find M-49A2C Tanker Deuce rear facing PTO shaft runs off transfer case ,a couple of pillow block bearing and mt another Deuce winch between rear rails ,bracket a roller fair -lead ,and its "ON LIKE DONKEY KONG!!!!" LOL
popacom........Bill Kagin III
:jumpin:
A Bobbed Deuce is really front heavy. If your going to run two winches, an electric winch on the front ( only 100 lbs ) and a 5 ton winch on the rear is a slick way to do it.
twright
Rockmart Ga. 30153
You can get a 10,000 mile marker winch off of a hummve all you need for the Hyd is a power steering pump and you
could also run off of a pto and you control it with 24 volts . I was thing about puting one on a DUCE with a wrecker
boom that way no chain fall to mess with just hit button up or down.
AEC Retired Tony
topo
219
farmington NM
I mounted a 45000 winch off a wrecker on the back of my m52a2 last year and it is ran off of the transfer case I can't pull a wide trailer but it pulls the m269 wrecker low boy and the m131a5c fuel trailer that is now used to carry water just fine .
buy a 13 hp wood spliter motor and hyd pump they have good pressure and could run independent of the truck motor.use quick attach hyd hoses and you could run any hyd accessorys you could think of.( pierce winches makes a20000 lb electric )
TaylorTradingCo
68
Ringgold, GA
No, you cannot simply "flip" the PTO, the gears would not lign up correctly. I have seen some say that you can pull the gear and shaft and reverse them inside the housing and then do it.
A simpler option would be to get a dual output PTO. It will bolt tight onn and you can power your front winch and a rear accessory at the same time with it. I have one for sale if anyone needs it. I also have a PTO pump from an old dump truck and several Duece front winches.
I have been thinking about this myself because I would like to get a M870A1 trailer which folds down flat for self loading, but it requires a rear winch to assemble/dissassemble like the truck that TOPO has shown.
Derek Taylor
