- 12,195
- 329
- 0
- gainesville, ga.
The m819/m246 tractor/wrecker AND the m815 bolster truck, and I beleive the hyd. lift gate m820 have a shiftable t-case pto.It should be noted that all the 800 series 5-tons I've seen have a non-shiftable t-case PTO. It turns any time the trans is in gear and the foot clutch is engaged. The wrecker uses the t-case PTO to power the wrecker bed and rear winch. Shifting is accomplished by use of a power divider that has neutral, power to the hyd pump for the crane, or power to the rear winch. There may be some other applications that use a t-case PTO on these trucks that are shiftable but the wrecker t-case PTO is coupled to the t-case all the time.
Also the 900 5ts t-case pto ONLY turns in one direction because it DRIVES a hyd. pump.
Sorry about the spelling, Google Spell Check does not seem to work with the non-upgrade CHANGE
