Sarge29
- 1
- 18
- Saluda, SC
When I got the 998 the right rear geared hub was not on it. The top control arm was missing also. I bought a top control arm and installed everything. Now after the test drive I have noticed that the right rear wheel is out too far at the top. Did I get the wrong top control arm? I did check the frame and everything is good there, also the lower control arm is good. The other problem is that the left side is about 1 1/2 inches higher than the right. What would cause that other than a weak spring. Again, the frame checks out good.
Thanks in advance for the help.
Sarge29
Sarge29
