Rear wheels stuck on
peglegwillie
Knoxville Tennseess
Could use some ideas here. The rear wheels on M1009 are stuck on axle. Tried to remove them after lug nuts and they won’t budge! Soaked them in Blaster couple times yet still not budging. I do know the area I bought it from uses a lot of salt on roads as by the surface rust on entire drivetrain. Any suggestions will be appreciated, Thank you
Dock Rocker
72
Jackson ms
First try going around the lip of the wheel with a hammer. Don’t bend the lip obviously.
If that doesn’t work put the other 3 wheels on the ground and support under the axle on the stick wheel. Get a long leaver like a 2x4 and try leverage across the face of the wheel.
When all of that doesn’t work loosen all of the lug nuts about 1/4 of the way and set the tire down completely and let it support the weight of the truck. Then put it in drive if it’s a front wheel or reverse if it’s a rear wheel and go for a few feet and slam on the breaks. Repeat until it breaks loose.
My nephews aluminum wheel and metal drum on his Toyota had a galvanic reaction and it almost welded them together. The loose lug nuts trick is sub optimal but it will work.
nyoffroad
682
Rochester NY
A heavy dead blow hammer works good and rarely damages the wheel, could also try loosening the nuts and heat the wheel in the center.
Ilikemtb999
44
Denver, CO
A bottle jack between the frame and tire with a block of wood up against the tire was always my method if dropping it down on the jack or rolling back and forth didn’t work. Be sure to keep the lug nuts half on because it’ll pop pretty good.
1,807
I've sat in front of the tire like I was removing it and kicked at it from the seated position. Usually works. On others I've used a prybar between the back of the rim and the drum. Just think, the brake drum will be even worse.
73m819
319
gainesville, ga.
Lower the truck till just before ground contact, place a long enough 6x6 to go across the rim, lay it on the ground up against the rim, if to low, build up under the 6x6, then use your BFH, I mean BFH, a couple of good hits shall set her free.
marchplumber
2,718
Peoria, Illinois
Ron,
We used to call that a BMFH.............................Pretty sure it is the same tool, but wanted to clarify!
LOL
73m819
319
gainesville, ga.
NOT a GOOD IDEA, you could get yourself DEAD.
MarcusOReallyus
814
Virginia
By the heat raising the tire pressure until the tire explodes, the same reason not to weld a wheel with a tire on it.
Anyone who can apply enough heat with a torch to blow up a wheel probably shouldn't be working on vehicles at all.
Yes, it can be done, but you really have to draw on some extra deep reserves of stupid to make it happen.
A little attention with a MAPP gas torch is how I got mine off just a few weeks ago. I guess I was fresh out of stupid that day, so everything worked out okay. Mind you, I probably have plenty more stupid built up in my account now, but that day I was pretty tapped out. I didn't manage to even warm up the rim, let alone the tire. Got the center hot enough to break it loose, though. It didn't really take much.
porkysplace
1,487
mid- michigan
There is plenty of that going around these days .
Mad Texan
1,150
Chester County, PA
It's ironic I replied to this as the fronts on my newly acquired M1010 are seized on. As soon as they wouldn't move I thought of this thread. Even swung a sledge at them... No Joy! Soaked the lug holes with PB for the night. Not walking away totally defeated, the rears came off...
Doh!
cucvrus
10,131
Jonestown Pennsylvania
I still stand by my statement. I heated a lot of lug nuts and wheels over the past 40 years. I never got one that hot that the tire pressure changed. If the tires were filled with hydrogen I would not be doing so. But I never heard of or seen anyone that was hurt in anyway by heating lug nuts or wheel centric. I may be poorly equipped but I welded pin holes shut on wheels while they had air in them. Tack welding and checking with a water hose. Welded a few flat washers at valve stems on filled tractor tires. Have a Great Day. On another note I ran with scissors also. And sang at the table.
MarcusOReallyus
814
Virginia
Oh, don't give the tire industry any ideas for more things to sell us! They'll claim it improves gas mileage by making your car lighter, or something! :cookoo:
Oh, now that's just over the top!
The singing, I mean. You could choke on some broccoli! :eek:
73m819
319
gainesville, ga.
The ISSUE is not the instant heat but the lingering heat, as the center heats, the heat has NO WHERE to go but out, which will heat the air contracting the rim, with the volume of air in the tire, and the tire NOT in ground moving contract to suck the heat away, the air just keeps expanding, since it does not take much heat to get the air expanded enough that SOMETHING has to give.
YOU may have been lucky and got away with heating for 40 years, that does not mean that the next heated wheel will not go bang, there is a REASON for the DO NOT HEAT WHEELS WITH AIRED UP TIRES, non aired up good tires will go bang, just takes longer.
So with the above said and you guys DO heat the wheel, you COULD HAVE a VERY bad day and a very upset family, and besides if you live, you will HEAR for ever afterwards "How come you did NOT check", just this alone makes the risk to high.
sandcobra164
288
Leesburg, GA
Simple way to defuse this conversation. Remove the valve core from a tire if using heat sources near the rim. Reinstall the valve core and inflate the tire afterwards. Too easy, not much extra work and we'll all be working safely.
