rear windows for the m1078
Cobbtowncowman
Cobbtown, GA
I use my m1078 for farm work. I am removing the flat bed and adding 5th wheel and gooseneck hitches for moving round bales off the fields, to the hay barns. The cabs on these trucks are already die-struck from the factory, indicating to me that maybe some version of this cab was designed to have rear windows. Does anyone know if any version or commercial equivalent (Steyr or MAN or some other) of this cab that had rear cab windows and if so where to get more info. I really would like to have a rear window.
Dock Rocker
71
Jackson ms
If you don’t want to go through that trouble a backup camera would be a great alternative.
Blairg
California
Anybody who does windows should be able to do a template and make those.
As they are flat they are not difficult. Sourcing rubber molding should be easy for them as well.
Ronmar
6,766
Port angeles wa
You would want to source the rubber seal material first so that you can cut the lip to the proper dimenion to match the frame groove in the rubber seal... You could also probably do it in plexiglass. Not as scratch resistant, but it also won’t shatter when one of the hands hucks a tie-down hook into it...
profo
70
jeanerette,la
Any place that works on large workboats can do it they make windows with the rubbers all the time down here in Louisana.
snowtrac nome
137
western alaska
If you don't want it to shatter better use lexan , acrylic will shatter. If you buy the gasket from the glass shop cutting your safety glass, they will know how much to allow for the gasket. All you will need is a good template of the opening.
