comdiver
- 1
- 0
- Buffalo NY
Does anyone have a set of instructions or a manual (anything) for the REB kit that they could share? Photos of the parts, parts breakdown. I would be happy to pay for copies and mailing.
The transfer case complete units are interchangeable - you just can't mix and match parts between the two styles.Bill W said:AW Crap!
I was just given ( as in free ) a sprag transfer with the thought of just changing out the air shift on my old unit That won't stay in high ( lever keeps dropping into neutral ) and blows oil everywhere. So they are NOT interchangable??
YES for the first (same dimensions, although they don't work the same way) and YES again, depending....... The good news are: all the parts that usually wear out first and make the TC pop out of gear actually are identical to both styles. Just the front output sections and the rear output shafts are different and NOT interchangeable, everything else is exactly the same!DDoyle said:The transfer case complete units are interchangeable - you just can't mix and match parts between the two styles.Bill W said:AW Crap!
I was just given ( as in free ) a sprag transfer with the thought of just changing out the air shift on my old unit That won't stay in high ( lever keeps dropping into neutral ) and blows oil everywhere. So they are NOT interchangeable??
DD
Oh yeah? try collecting railroad equipment!Bill W said:crap I thought this was going to be easy..why did I pick a hobby that had to weigh so much!!!
No, the sprag case doesn't work that way. The linkage from the transmission does not engage and disengage the front wheel drive; it changes the direction of the one-way sprag clutch. The front drive works in all transmission gears.mucekok said:both my trucks have the sprag style case, i am consideribg removing the linkage from the trans that engages the front drive only in 1st and reverse, and building a seperate lever to engage front drive at my will. looks like that's what the kit pictured does. am i correct?
