- 524
- 1,127
- 93
- Germany
Fortunately not as much of a challenge as using sheetmetal with as little rework as possible. Thanks again for sharing your expierence. That make it for other easy to follow.When you go to mount the inner fuel neck housing you will need to modify the right side of the housing in order for the door hinge to clear. You will also need to drill a new 9/32" hole in the sheet metal in order to mount the housing to the fender. See attached. Hope this helps.
Also if the costs was high for that addtional tank it make the truck with the new drivetrain to a comfortable full daily driver with a lot of options.
