Jeepsinker
- 456
- 83
- Dry Creek, Louisiana
For those of you who may need to rebuild your transfer case pto:
Front and rear bearings: Timken #342
Races: Timken #332
output seal: T.b.d when I get it cleaned up and cross the numbers
mounting flange gasket: Surplus, same as t-case bearing cap gasket.
Mine sat for a very long time unused on the truck it was on and the bearings had locked up from rust caused by accumulated condensation, much the same as the Garwood winches do.
Races: Timken #332
